First, I will include a photo of another engine someone on this site sent me so I could use it to help me install this one...same set up. You can tell which one is mine and not mine. I installed this throttle kit on my briggs 5hp. It has absolutely no response to the engine when I twist the throttle. It moves the throttle on the engine back and forth and you can see it move everything that's attached to it. When I had it installed on the throttle on top of the engine, everything worked fine. But Everyone kept commenting on my photos to change it to the throttle that's causing me all the problems now. Twist throttle moves what it's suppose to but no reaction....also, it runs like crap now and will not idle/stalls out with this so called better throttle set up. Can you see if I'm doing anything wrong? Thanks.:censure::shrug:
