I’ve got an HS40 that I had someone do work on. They said they replaced an exhaust valve, piston rings, honed the cylinder, new lighting flywheel, He said the valve guide looked worn but seemed ok with a the new valve. When running the engine, it always seemed to take a few tries to get it going, but one it startled would idle just fine. However when putting any kind of load on it the engine seems to bog down and sputter. Then idle fine, but just had no power under load. Opened it up to see this:
Am I looking at oil getting past the rings here or past the exh valve guide. I can feel the scoring on the wall of the cylinder by the valves. It’s only been run a handful of times since I got it back. Never seemed to have the power it should have. Feel like I’ve been had.
