Oil splattering on my leg
Oil is fliing out of my clutch when I ride . I thought maybe it was because it was a new clutch and it would stop after some time .it haze not . Is this normal ? It shurly is annoying . Any suggestions ?
Take a paper towel with you.:laugh: On a serious note, do you have a chain guard? It probably is chain oil. Maybe you over oiled the clutch bushing. More oil is better than none.:thumbsup:
All great suggestions. Maybe even ride around naked in saran wrap . It probably is the chain. I do have a chain guard on it I thought that would fix the problem. But it is a real small chain guard.
capguncowboy
the parts where the chain will sling oil is the places it changes direction. Depending on where you're getting hit with oil on your leg, it could be the chain. It's also possible it's blowing out of the oil breather housing just below the valves
