So I just got the arc 1st and 3rd generation billet flywheel from OldMiniBikes and when I was installing it was rubbing on the crankcase I grinded down the studs behind the flywheel and it still grinds. Then after looking closer I noticed that the center hole where it mounts to the tapered part of the crankshaft is a little oversized and its sliding into the crank too far and rubbing. Does anyone know if this is the correct flywheel or if it really even works. Any help would be appreciated.
