also another question I saw that someone said if a run a hemi piston it will have more compression. could I swap a hemi piston from my second predator into it?
Dang I sure missed a bunch, lol.
These guys are spot on, it needs oil.
I've lost cam lobes on new outta the box engines. Its the exhaust lobe that goes 1st. Im fairley certain it happens in the 1st 30 mins of break in.
I've changed the way I prep the new outta the box engines, all of them not jus preds. No more outta the box, in the vehicle and run it. Some problem would alway show up, eventually. Might be jus a simple carb nuts loosened, side cover bolts backing out. Major problems, oil consumption, new sparkplug covered with oil in just a few hrs.
I suggest, putting the stock springs back in for break in period.
MAKE SURE, all bolts are torqued to spec, valves lashed at .003", coil air gap at .045" for that flywheel with stock coil, stock timing key. The stock carb will be better for break in, its dam near perfect outta the box with that lean stock jet for breaking in. Too much fuel during break in, will wash the rings and they MIGHT NOT ever seat.
Make sure it is mounted down solid, I like it level, most of my builds will be on a level engine plate.
I use 30w oil with a tiny drop of zddp, for break in.
Magnetic drain plugs will show you how much metal comes outta these thing during break in. If you don't have any, do the best you can with what you got.
Start it up and get it above 2500 asap, get that oil splashing!!!!
I use up and down throttle/rpm for the 1st 30 minutes, dont let it set at 1 steady rpm very long, keep it moving, and don't let it under 2500, turn idle screw up if you need to.
After 1st 30 mins, you can do some 2500- WOT quick fast snaps, jus dont hold it WOT.
This changing in rpm will change the temps of the metals. These engines run very cool, it takes awhile to get that oil up to temp
We gotta get that oil up to temp, so try to run it at least 1 hr, more is better, but at least 1 hr, on the 1st day. This is a HOT CYCLE.
After the 1st hr, drain oil, fill it back up with your flavor of break in oil, let it set over night. This is a COLD CYCLE.
Next day, check the bolt torque specs again, not the rod bolts they should be fine since your checked them during the prep.
Flywheel nut, head bolts, side cover bolts. Some might need torqued again, new bolts do stretch.
Always check, set valve lash last, they will be slightly looser then .003" make a note, this will tell you if you are wiping a lobe. Set em again at .003".
Another 1 hr of run time, you can let it set at steady rpm a little longer now, we done got the cam broke in good, hopefully.
Another drain and fill, let sit over night, check bolts again, set valve lash again, make notes again.
My engines stay on the test stand for 4-5 days, getting ran and checked everyday. The bolts and valve lash will eventually stay put, that tells me, it's broke in, and no bolts will come loose. Some minis have to have the engine pulled jus to check/set valve lash.
Let's get some run time, fun time, smiles per hour 1st,....... then we can look at heavier springs, pistons and such.
Hope this helps.
