I have a predator 212 with 3.308 ARC rod, ARC flywheel, stock dish piston, RTC-6 (stock 27/25mm valve) milled 0.050 off, 1.3 rockers with stock cam, 8 degree key and mikuni 22mm carb. My bike is a Manco with Maxitorque 10T clutch, 43T rear (4.30 gear ratio), stock 16" tires with paddel brake. Bike goes 67mph at the end of 1/4 mile. The clutch is slipping big time out the hole.
I'm upgrading to ARC 3.048 rod, flat top piston, (27/25mm SS valves), 5.5 valve guides and ISKY black mamba Sr. cam. I was thinking of upgrading my carb to 26mm mikuni or Tillotson alcohol. I don't care of the cost of fuel. My bike upgrades will be Honda Z50 front and rear wheels (drum brakes), bully 2 disc 428 chain 11T clutch, 47T rear spocket. Should a carb size increase be good or stay with 22mm mikuni????
