Replacement front end
Lotar
New Member
Hey y'all. Does anyone know if the front end made by AZUSA fits on a DB 30S and if so without modifying? Unless I just overlooked it I couldn't find a factory front end replacement for the DB. Thanks.
bandit 40
You will have to measure the fork necks on both makes. But pretty sure the Head bolts are different sizes all together anyways meaning , you would have to close the azusa fork holes up and re-drill to meet the DB bearing size.
Lotar
New Member
Thanks bandit40. Figured it was worth asking but sounds like alot of work. I just have a small bend on the throttle side where the handlebar meets the top fork plate, not very noticeable. Probably just live with it.
gbabins1
I have an extra DB handlebar/fork if you want it. They do have a slight bend in them towards to top somewhere but not that noticeable. You're welcome to it if you want?
Lotar
New Member
Wow thank you very much. I'll see if I can correct the bend, it's not that bad. But if that goes sideways I may take you up on that very kind offer sir.
I do like that look. I ordered the forks in use on the current DB 30 from OldMiniBikes warehouse. Sure wish I went with the Motovox forks...
