I have a Robin EX21 that had been sitting for over a year. Prior to storage it was running properly but was not stored correctly. Recently I cleaned it all up and slapped on a new carb (broke the idle screw off the old one trying to clean it properly). The carb/throttle linkage is set to as it was prior and the engine will start on the first or secoond pull no problem. The problem comes when once started it will not go to idle and just runs wide open almost full RPM. I can pull the linkage and governer arm back to the idle position and it idles perfectly purrs like a kitten, but once i let it go its back to wide open. Its running as if the governer is holding it in the wide open position. I want to know is it possible that the governer centrifical weights maybe be stuck in the wide open position not allowing the governer to return to the idel position? Is this something that happens? Is there an easy way to check to see if that is the problem or am i going to have to crack open the case to check it? Could there be something else wrong with the governer setup?
Thanks for any help you can give me!
Steven
R.I.P. RudeDog
Steven
R.I.P. RudeDog
