Started up a B&S 3HP (80202) for the first time (for me) and I'm seeing sparks/arcing coming off the throttle arm and the governor arm, why would this be happening?
Yes that can happen...... If you have a newer style mower with the bail handle to stop the engine and disconnect the coil wire to kill the engine and touch the wire to a bolt it will spark. I do it all the time when I redo a engine. Until I get a new cable or install a switch of course ...... The question is. does it miss or want to die out when the spark is happening ???/
