OK good to know gov is working right! I did loosen a few of the gov screws just to get the links on and tightened screws. Is the gov adjustment critical? Should I do the gov adjustment that's in manual?
Another reason I ask about gov adj is the bike runs great with carb gov arrow lever in middle position. Is it ok to run with gov lever in middle position? If I put gov all the way to off position bike runs rough and / or stalls out!
Duh, does it matter what drain plug to use for oil change? And if I read specs right use straight 30 weight oil?
Thanks
Thanks
