Given that shorter stroke cranks are stiffer, flex less and piston speeds are lower at any given rpm, they are capable of turning higher rpm.
I wasn't aware the Snow Kings ran looser tolerances, I know the exhaust valve on a snow thrower takes a lot of punishment as the engine is constantly run at around 3,600rpm even when it's not under load.
As the amount of ignition advance is fixed, assuming the amount of advance has been reduced to aid starting therefore is way less than the engine could actual use, there's a flame passing over that exhaust valve the whole time the engine is running.
The exhaust valve/guide does certainly seem to suffer, particularly the guide. Both the HSSK50 engines I own have what I would normally consider a sloppy exhaust valve, but I've been told this was by design, whether this was the same on the H and HS minibike engines I don't know. Can anyone shed light on this?
My main question is whether anyone has experienced running the rarer 46.8mm short stroke configuration that Tecumseh introduced for 2 or 3 years in the HSSK50.
Why Tecumseh chose to reduce capacity by 10cc on their 5hp engine just for a couple of years I don't know, perhaps they were just using up surplus stock of cranks from another less popular engine, perhaps it was the only at introduction of the HSSK50, but it didn't take long for them to change back to the 49.23mm stroke.
It is interesting that Tecumseh's power/torque curve graphs produced sometime in the 80's are only plotted up to 3600 ... yet the later winter engines with the 49.23mm stroke specify the governor set at 3750.
As much as I love this simple, and somewhat crude little engine, Tecumseh's literature, amount of different engine configurations, tolerances and clearances seem to be a complete mish mash and differ depending on what you read, who wrote it, or when it was written ... v. confusing!
But I am still really curious, even if I don't max my engines out ... what kind of rpms do you guys see on your modified engines? And has anyone any experience with running this rarer little short stroke motor?
