Tecumseh shroud
I’m changing my h35 engine from points to solid state replaced flywheel and coil. Will my shroud fit and recoil work on this set up?
Can you post a picture of your shroud so someone can give you an educated answer? Did you remove a coil from inside the flywheel and mount a coil above the flywheel on the cylinder?
If you already replaced the coil, why not try installing the shroud and let us know if it fits?
