I bought the 730136A control. My first time hooking up a thottle
control. Please bare with me.
Is there a part number or size for the cable barrel/clamp end to fit into the control? I want to make sure to get the correct part. Would Home Dep. or Tractor Supply have it?
To attach the new control to my Tec. 3.5. How do I remove the current factory throttle? Drill out rivets? Chisel or flat screwdriver? I think it is riveted to the blower housing.
There is a wire running to the current factory throttle. Kill switch? What do I do with it once I remove the factory throttle?
Do I need to remove the metal tang circled in blue? Should the screw be
all the way in or how far out from the tight position?
Thanks!
Thanks!
