$1200.00
Located in Mount Airy Maryland 21771.
Local Pick Up Only!
For your consideration is a nice original survivor Trail Blazer mini bike with the original 1971 Tecumseh H35 3.5hp engine. This bike has great compression and runs well! The engine is immaculate for being original. The decals and paint are very nice and the seat is amazing.I had to replace the rear brake cable and I also made a steel flat bracket to cover up a crack on the top of the chain guuard where the mounting bolt goes. That way if you ride the bike it will hopefully help it from getting worse. I put a piece on the top and inside on the bottom. The mouting screw holds them on. New points and condensor aswell. Overall this is a super clean bike! Looks like somone put a new Genuine Tecumseh HS40 carburetor on at some point. I also painted the air cleaner silver they did a custom job on that. Has a nice mercury clutch. Goodyear 5.30x4.50-6 tire in the rear and a Carlisle 5.30x4.50-6 tire up front. Fresh oil change with VR1 sae30. Please message me with any questions you may have.
Trail Blazer - Code 5617 0443 Model J1015
Tecumseh - H35-45340H Serial 11240
Video of the bike running below copy and paste -
Local Pick Up Only!
