That was a Scat Cat, not a Ding How. Two different brand bikes. The Ding How frame had a much taller rise on the back tubes before it angled up. The angle portion is much shorter on the Ding How. The seat on the Scat Cat used shocks to give it suspension that mounted from the seat down to the axle mounts, the Ding How used springs that mounted to the top of the frame. The axle mounts are different as well as the width and length of the frame, foot peg location, and forks. It looks like someone cut off the front portion of the frame and built their own design neck support which shortened the frame. This brochure doesn't show the small wheeled version of that frame but you get the idea.
you can even see the top of the frame/rear,where they Bent the frame bars.
wonder how they bent that up at the front?
the flat fork brackets been cut off....that rear seat mount looks..odd?
do you have better pics of this?
did you buy it?
did you buy it?
