Tapping the holes to full depth and installing good studs, is an upgrade.
You went sideways, at best. TSC $3.99/lb Grade 8 is backward.
Cranking cylinder pressure is a function of static compression less cam bleed-off.
Dynamic compression ratio is the item to math out.
Super high compression would require welding the chamber.
Higher pressures reduce power at high revs, and beat up the rod at low revs. Great midrange though, I guess.
Excess milling just weakens the clamping of the head, making gasket failure more likely.
