Yet Another Bonanza Frame
Here's the next Bonanza frame from the pile. Can anyone identify the model?
http://www.lbhvacr.com/OldMiniBikes/softtail1.jpg
http://www.lbhvacr.com/OldMiniBikes/softtail2.jpg
http://www.lbhvacr.com/OldMiniBikes/softtail3.jpg
And what is that little boss on the left rear frame tube for?
I'm hoping this is the swingarm for this frame:
http://www.lbhvacr.com/OldMiniBikes/swingarm1.jpg
Its a BC 1200 or a bc1300. Yes thats a cable stop but it shouldn't be in that spot. They were in that spot for the BC 1100. The cable stop for that model should be on the bottom of the swing arm.
george3
Somebody bought that swing arm and mounted the Shock mounts to make it a 1300 instead of a 1000 or 1100. 1200 and 1300 have rear shocks. check other top shock mount bikes you will see the two mounts were added. Is the angle of the pic. showing me they are welded on crooked. Run a long bolt or rod from mount to mount see if it will slide in. if not cut and re weld with rod installed to square them up. If there not oem.
who would do succh athing.....ME the rear axel mount was cut off of this frame and swing arm and shock mounts added its 7/8 tubing also
good eye george
