User Tag List
Thanks Thanks:  1
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Member
    Join Date
    Dec 2016
    Location
    florida
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Coleman 200 Seat Suspension...Installed
    I put this together about a month ago. Works well, especially off road in bumpy areas...Replaced original base with 3/4" plywood, bolted 2 valve springs to it with fender washers and lock nuts on the back side, bent a right angle in a 6" T hinge for the front and added a piece of 1/2" plywood at the rear. The springs are wide enough to bear thru the plywood to the frame. Used original seat mounting holes to bolt to.
  2. Thanks Raskin thanked for this post
  3. #2
    Raskin's Avatar
    Join Date
    Jul 2016
    Location
    Florida
    Posts
    1,123
    Mentioned
    9 Post(s)
    Tagged
    0 Thread(s)
    Rides
    That's cool..anything helps..ya know you can get bobber seat springs that you can secure with bolts because they got eyes on both ends..
  4. #3
    Member
    Join Date
    Dec 2016
    Location
    florida
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I got bobber springs and they were so stiff that they wouldn't compress, at all. These valve springs have just the right amount of force to compress just a bit when you are stationary.
  5. #4
    Raskin's Avatar
    Join Date
    Jul 2016
    Location
    Florida
    Posts
    1,123
    Mentioned
    9 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by renovate7 View Post
    Ahhh ok yeah they are stiffer..i do weigh a bit
  6. #5
    Junior Member
    Join Date
    Mar 2017
    Location
    Michigan
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    That's pretty cool. I like those Coleman 200s. Look like a lot of fun. If I can find one for a good price I may get one.
  7. #6
    Tom S.'s Avatar
    Join Date
    Feb 2008
    Location
    Hillsboro, Ore.
    Posts
    5,100
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I put this together about a month ago...
    http://www.facebook.com/NorthwestTrackShots
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
