User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Junior Member
    Join Date
    May 2017
    Location
    Kansas City
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    COLEMAN CT200U. Torque converter?
    Any ideas on the best way to drop the clutch and put a TC on these?
  2. #2
    Senior Member
    Join Date
    Feb 2017
    Location
    Ohio
    Posts
    179
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    First check the size of the crankshaft's output. If it is 5/8" the you will not find a TAV for it. You need a 3/4" crankshaft (PTO) output. After that it is pretty straight forward. This video will give you the idea whether you have a predator or the original clone that came with the bike.
  3. #3
    Junior Member
    Join Date
    May 2017
    Location
    Kansas City
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Do I need to remover the clutch to measure that? Am I better off just selling the motor that it came with if its a smaller diameter and installing a predator?
  4. #4
    Senior Member
    Join Date
    Feb 2017
    Location
    Ohio
    Posts
    179
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    It can be measured with the clutch bolt and washer removed from the end of the crankshaft.
    If you do not want to open up your engine to replace the crankshaft (appx $35), then sell your Hisun and buy a predator. Before you sell the Hisun and its gas tank you may want to see if the Hisun's tank can be used on the predator. You will then not have the gas cap issue that you see in the video. It should fit.
    If I was in your situation I would just order a clone crankshaft and swap it out. But that's just me. Others have bought a new engine just to make the torque convertor install easier.
  5. #5
    Join Date
    Aug 2016
    Location
    White Lake , Michigan
    Posts
    990
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I thought I saw an adapter sleeve somewhere that fit on the 5/8" crank and allowed a 3/4" clutch to fit. The adapter had a key with it.
    I just looked but can't find where I saw it... :-(
    That would be the cheapest and easiest thing to use. I'll keep searching. If I find it I'll post it.
    Danford1
  6. #6
    Join Date
    Aug 2016
    Location
    Posts
    990
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Join Date
    Apr 2017
    Location
    Orygun
    Posts
    26
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    From SAS289 "The factory Coleman engine's shaft size can be figured out by the last 6 digits of the VIN. Last 6 037962 and after are 5/8. Any number before that has the 3/4" shaft."
  8. #8
    Junior Member
    Join Date
    May 2017
    Location
    Kansas City
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Also is Ebay the way to go and I'll probably get the chinese kit but want to order a good belt as well as a spare belt to throw in an ammo box that Im going to mount with some tools so I'll have a small repair kit on the bike at all times.
  9. #9
    FOMOGO's Avatar
    Join Date
    Jan 2016
    Location
    Upstate, SC
    Posts
    1,688
    Mentioned
    23 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by michaelj1978 View Post
    OMB Warehouse is the place to go for parts.
    Here is a link to the Toque Converter.
    https://www.ombwarehouse.com/torque-...-41-chain.html
    Here is a link to the belt.
    https://www.ombwarehouse.com/-9-7-belt-asymmetric.html
    And anything else you might need.
    Doug
  10. #10
    Charles S's Avatar
    Join Date
    Mar 2017
    Location
    SE VA
    Posts
    159
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    A clever OMB member installed a torque converter on a CT100U with a 5/8" shaft.
    https://www.oldminibikes.com/forum/m...man-ct100.html
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
