User Tag List
Thanks Thanks:  3
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 5 of 5
  1. #1
    Senior Member
    Join Date
    Apr 2016
    Location
    Norwalk ct
    Posts
    484
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    2 speed jackshaft won't shift
    I have 2 Trailhorse's one with a brand new 2 speed and one with the original 1970 2 speed and nether of them seem to shift. Not sure if the Rmp's or speed isn't getting up high enough to shift? Both have new predator engines. Any ideas. Thanks
  2. #2
    FOMOGO's Avatar
    Join Date
    Jan 2016
    Location
    Upstate, SC
    Posts
    2,283
    Mentioned
    44 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Bryce this is on my list also. I have a Trail Horse for the wife and purchased a 2 speed for it at Andy's suggestion and have no clue how to set one up so I am following along.
    I am all ears.
    Thanks for bringing this up as I would have to ask the same questions.
    Doug
    "A day without laughter is a day wasted." - Charlie Chaplin
    If stupid could fly you would be a jet.
    Duct tape cant fix stupid but it can muffle the sound.
  3. #3
    Senior Member
    Join Date
    Apr 2016
    Location
    Norwalk ct
    Posts
    484
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Anyone??? Can't figure it out seems like it's revving out and not shifting.
  4. #4
    Sho-nuff minibikin''s Avatar
    Join Date
    Aug 2007
    Location
    Pennsburg, PA 18073
    Posts
    8,308
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The only advice I can offer is the jackshaft has to spin at enough rpms to engage that Clutch. So, plug your info into the comp cams gear ratio sticky in the engine thread. It will give you jackshaft RPM. Then, maybe a spring adjustment?
    My original sears super 2 speed showed, but it wasn't really noticeable other than you kept picking up speed.
    Bye Felicia!
  5. Thanks FOMOGO thanked for this post
  6. #5
    Senior Member markus's Avatar
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    10,473
    Mentioned
    32 Post(s)
    Tagged
    0 Thread(s)
    Rides
    They usually dump into 2nd a lot sooner than you want them to when working correctly I would check that you put the 1st gear on in the correct rotation. If you packed it full of grease thats gotta go, If you just bolted it on off the shelf that its been sitting on for the last 40 years, the old hardened grease has to be cleaned out so it can free wheel easy as well. I use a little grease-just enough to thin coat the pieces during assembly but use an old style oiler can to get some oil down into it when all assembled, and oil it that way often.
    on the 2nd gear/clutch There are 2 positions it can go in:
    Of course good alignment, spacing, and chain play are a big factor in how it perfoms as well. The only dual gear clutch available anymore is from max torque, and I dont think it lines as good as the original comet made clutches, it still works but its a little more tedious to set up.
  7. Thanks manchester1, FOMOGO thanked for this post
Posting Permissions
  • You may not post replies
  • You may not edit your posts
