User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Member
    Join Date
    Feb 2009
    Posts
    58
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I have the original grips. Do you suggest this set up as an upgrade?
  2. #22
    Join Date
    Aug 2016
    Location
    White Lake , Michigan
    Posts
    1,621
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by KMR View Post
    No, not an upgrade. Use whatever grips you prefer. Grips become a personal preference unless you are trying to be factory correct.
    The grips that come with it work fine however.
    Danford1
    Time is the best teacher. Unfortunately it kills all of its students.
  3. #23
    Member
    Join Date
    Feb 2009
    Posts
    58
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Maybe I will just go with a 48 or 50 inch and cut it. Thanks
  4. #24
    Member
    Join Date
    Feb 2009
    Posts
    58
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Join Date
    Aug 2016
    Location
    Posts
    1,621
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Looks good as long as your twist grip is in good shape and works freely.
    Danford1
  6. #26
    Dr. Shop Teacher's Avatar
    Join Date
    Feb 2015
    Location
    Falmouth, Virginia
    Posts
    3,399
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Welcome to T-Bird world. If you're intent on this being for your 11 yr old, keep the H35 on the bike as that was the original size engine. The large rear wheel sprocket is best suited to that size engine. This bike is prone to wheelies even with the H35. A Predator or Honda engine of more than 4 hp will be too much for an 11 yr old (even a 58 yr old like me) unless you change out that rear sprocket to a 60t. Definitely add a clutch brake. I made up a girdle to brace the engine plate rather than welding anything on the plate. The girdle locked the engine in place. Here's my build start to finish:
    https://www.oldminibikes.com/forum/p...get-build.html
    Wilderness~Copperhead~Trail Bike
Posting Permissions
  • You may not post replies
  • You may not edit your posts
