User Tag List
Thanks Thanks:  4
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Member
    Join Date
    Dec 2017
    Location
    NC
    Posts
    41
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Tuning a centrifugal clutch for hill climbing
    Would a higher engagement rpm help with hill climbing?
  2. #2
    Member
    Join Date
    Sep 2017
    Location
    Ohio
    Posts
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    If the engagement is set to an rpm closer to your power band - yes it should. Engagements set too low will definitely affect hill climbing as the rpms struggle to get into the engines power range.
  3. #3
    Member
    Join Date
    Dec 2017
    Location
    NC
    Posts
    41
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Is it possible just to cut a few loops off the spring to tighten it up?
  4. #4
    Member
    Join Date
    Sep 2017
    Location
    Ohio
    Posts
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I run a Hilliard clutch and just swap springs. I would not cut them. Springs are relatively cheap so just buy a couple with different engagements.
  5. Thanks Techmaven thanked for this post
  6. #5
    Senior Member
    Join Date
    Feb 2017
    Location
    Ohio
    Posts
    388
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Hopefully your gearing is where you want/need it.
  7. Thanks Havasu Dave thanked for this post
  8. #6
    Havasu Dave's Avatar
    Join Date
    Jul 2012
    Location
    Lake Havasu, AZ
    Posts
    8,580
    Mentioned
    16 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by SAS289 View Post
    Exactly. The clutch engagement is only for initial acceleration, and will do nothing once shoes are engaged at whatever RPM the springs dictate.
    Has anybody seen the bridge?
  9. Thanks mrpat thanked for this post
  10. #7
    Member
    Join Date
    Dec 2017
    Location
    NC
    Posts
    41
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Good point. I put a 60 tooth rear sprocket on my Coleman 200 EX, but maybe I need more. I was able to climb the hill in question initially with a bit of clutch grab/release at the very top but have since the ability to get to the top despite a few mild engine mods that have improved power. I haven't smoked the clutch at all, but it is possible that some of the grease I used on the needle bearing (white lithium) has migrated out. I'll give it a good cleaning, scuff up the contact surfaces, and see what that does.
    The more I think about it, higher engagement RPMs would help you get started up a hill, but if the clutch is disengaging on the hill, you would need more power or more gear. My 225 lbs isn't helping anything, either!
  11. #8
    Member
    Join Date
    Dec 2017
    Location
    NC
    Posts
    41
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Here is a climb I made on the hill in question right after I changed the sprocket. Now I stop 10 ft shy of the top.
  12. #9
    Member
    Join Date
    Dec 2017
    Location
    NC
    Posts
    41
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Hmmm, maybe I need more posts before I can post a link...
  13. #10
    Senior Member TheDullCarbide's Avatar
    Join Date
    Aug 2017
    Location
    Allentown, PA
    Posts
    397
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by MJL View Post
    Yes you do.
    Honestly, you have to tune the clutch by feel, not rpm. You need to "feel" where your TORQUE band is in your engine and tune your clutch have a stall right at your peak TORQUE rpm. Then you need to gear to have your engine pull the majority of the hill at the rpm of peak POWER. This combination will get you up the hill as FAST as possible (gearing for peak power) and it will be able to provide the most torque available even if the clutch starts to slip (clutch stall at peak torque).
    Also, this is the perfect application for a TC. A TC can keep your engine at peak power (get up the hill FAST) at a wide range of ground speed whereas a clutch will only provide a single ground speed at peak power. A TC should be tuned to stall at the engine's peak torque and shift at the engine's peak power. In the end, think of it as a clutch that automatically tunes the gearing to achieve peak power dependent on ground speed.
  14. Thanks MJL thanked for this post
Posting Permissions
  • You may not post replies
  • You may not edit your posts
