User Tag List
Thanks Thanks:  1
Likes Likes:  0
Dislikes Dislikes:  0
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Member
    Join Date
    Jan 2012
    Location
    Midwest
    Posts
    55
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I have taken the bike out for two test rides and the chain broke on both runs. I thought I had it lined up on the drive pulley of the TAV but something is not right. The connecting link came apart both times. Any thoughts?
  2. #22
    TANKSAREUS's Avatar
    Join Date
    Nov 2011
    Location
    Cape Town -South Africa
    Posts
    3,731
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    TM,
    The spring clip on one of my chains did not seat to well in the grooves, but seeing as this has happened twice it can't just be the link.
    Do you have a pic showing the alignment.
    Simple trick i use is a piece of fishing line, hold it against the rear sprocket at the most rear point , then move it forward till it touches the other side of the rear sprocket ( see Pic) This works better than a straight edge as you can have the clutch on the engine and line up up with the smaller sprocket.
  3. #23
    Senior Member Dragbikemini's Avatar
    Join Date
    Dec 2011
    Location
    Brewster, NY
    Posts
    1,522
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Way to hang tuff Kid! Looks great!
  4. #24
    Member
    Join Date
    Jan 2012
    Location
    Midwest
    Posts
    55
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by TANKSAREUS View Post
    TM,
    Thanks for the tip. I followed your advice and had better luck. I did a couple of "full power" runs on the bike tonight and the chain was fine.
    One more thought:
    Wide open throttle + TAV + 9 hp = Wheelie +
    This bike has some grunt! The top speed is not great but it has an outstanding hole shot.
  5. #25
    Member
    Join Date
    Jan 2012
    Location
    Midwest
    Posts
    55
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The Bad Dog project continues....
    Today I had a little time so I sanded and primed the frame, painted some engine parts, and treated the aluminum wheels to Shark Skin. The Shark Skin should keep the wheels and fenders looking good. I am going for a military/utility look. The paint is an olive drab and the aluminum will be unpolished but bright.
  6. #26
    Member
    Join Date
    Jan 2012
    Location
    Midwest
    Posts
    55
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Another pic...
  7. #27
    Junior Member
    Join Date
    Aug 2011
    Location
    Culpeper, VA
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Resurrecting an old thread.....I just received my Bad Dog Gigantic kit....to make things easy I went with a 10HP Tec...according to Robin this will make things easy so far as my Comet bolting/lining up....
    I do have a question....when you put the wheels on did you center them in the forks/frame and then line the engine up, or did you line the rear end up and cut your spacers based on that, and then center the front....Honestly when Robin said everything would line up I assumed (my fault) that he would have "mocked" it all up and cut the spacers....
    Not a problem, just not not what I expected....
  8. #28
    Junior Member
    Join Date
    Aug 2015
    Location
    Mississippi
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Tmuenster View Post
    Another pic...
    Hello. I've enjoyed looking at your bike. Do you have pictures of it completed? I would like to see a photo of this all the way done.
    I am planning a similar build. I've decided I like the fenders. Thanks, Stanley
  9. #29
    Junior Member
    Join Date
    Dec 2016
    Location
    Atlanta, GA
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Hey Guys. Just got a Bad Dog Gigantic.
    What did you all end up cutting the spacers to for the wheels? The kit ships with the spacer sleeve, that you need to cut down to size, but i have no idea what's the correct size. Please let me know if you wouldn't mind!
    Cheers!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
