IMG_0716.JPG I got my wheels back and my luck being the way it is the metal kept out gassing on 2 of the wheel halves causing a couple of small blisters. Another had a little bit of corrosion so I thought and when sand blasted it revealed a crater. I drilled and tapped that one and used it for the sprocket side, for the other 2 I'm not sure what I'm going to do. Now I have to make a lug for the drum brake and I'm waiting on a pile of parts.
