User Tag List
Thanks Thanks:  4
Likes Likes:  0
Dislikes Dislikes:  0
Page 5 of 5 FirstFirst 12345
Results 41 to 46 of 46
Thread: First Mini Bike
  1. #41
    Senior Member Fantic Freddy's Avatar
    Join Date
    Jul 2016
    Location
    Macedonia, Ohio
    Posts
    695
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I've had good results just putting liquid floor wax over chrome spray paint after the paint has cured for a couple weeks. It doesn't dull the paint finish. There's also a Meguire's spray wax finish that works too, the name escapes me right now.
  2. #42
    Senior Member Steve73's Avatar
    Join Date
    Nov 2015
    Location
    Tacoma, wa.
    Posts
    344
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Cpl2442 View Post
    Thinking about picking up some chrome spray paint for the handle bars.
    I tried chrome spray paint with no luck either. What I found out is that krylon makes a pretty awesome metallic spray paint that Iíve used with great success and clear coating with 2k clear worked out great. I used the 2k clear that cures in a couple of hours instead of 24hrs.
  3. #43
    Member Cpl2442's Avatar
    Join Date
    Aug 2017
    Location
    West Michigan
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    So all intek/animal/206 Briggs engines have the “studs” in the block for an alternator and starter. Whether they are drilled and tapped for it depends on the model. (From what I can tell, the animal blocks are all drilled and tapped). On my version of the Intek, all 4 holes were drilled. And only the top 2 were tapped.
    I tapped the bottom “studs”. They use #8-36. And ordered 2 more bolts from Briggs to attached new alternator that should push out 5 amps DC with my flywheel. Below was the previous alternator...
    Here is the new alternator...
    This new set up, if it works should be enough to run lights and have enough extra to top off the battery for the 12v starter that also on the way, and not sure if it will fit/work yet.
  4. #44
    Join Date
    Aug 2017
    Location
    West Michigan
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Also set up the red neck paint booth. Despite all the negative experiences with chrome spray paint, we are gonna try it. 29051AD4-DE69-4B92-B84D-7789233B6D65.jpeg
  5. #45
    Join Date
    Aug 2017
    Location
    West Michigan
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    So the chrome spray paint is awesome. Until you try to clear coat it, then it just turns into gray. You guys were right.
    Anyways, got the frame painted with hammered black and clear coated. Not meant to be permanent, just to stop the rust from having free reign until power coating.
  6. #46
    Join Date
    Jul 2016
    Location
    Macedonia, Ohio
    Posts
    695
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    You got some overspray on Barbie's Pink Jeep.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
