User Tag List
Thanks Thanks:  1
Likes Likes:  0
Dislikes Dislikes:  0
Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
  1. #31
    LSCustoms's Avatar
    Join Date
    Sep 2013
    Location
    So Cal
    Posts
    3,614
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    great job... thought about laser cutting my own too... just no time to get to the shop... great job...
  2. #32
    Junior Member
    Join Date
    May 2015
    Location
    PNW
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by LSCustoms View Post
    Just get a plasma cutter and call it a day.
  3. #33
    LSCustoms's Avatar
    Join Date
    Sep 2013
    Location
    So Cal
    Posts
    3,614
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Bad-Medicine View Post
    I have a plasma cutter.. easier for me to laser cut it
  4. #34
    Tom S.'s Avatar
    Join Date
    Feb 2008
    Location
    Hillsboro, Ore.
    Posts
    5,583
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Sure, this is an old thread, but I haven't seen much discussion about blast cabinets in quite awhile. My kid's boss bought an HF blast cabinet recently and he really likes it. He followed the tips in the reviews and sealed its seams well with silicone before he ever turned it on.
    Yesterday I picked up this Nesco (made in USA!) cabinet. This cab has floated around my circle of friends for the past twenty years, at least. Its seams are welded, so there are fewer potential leak points. The gloves and window are in good shape but it needs a new hose or two, and I should probably add a dryer to my air line. It came w/two guns and a handful of tips in different sizes. The back has been extended so you can get larger items inside, but it won't take a minibike frame.
    I bought a Campbell Hausfeld compressor at Montgomery Ward on 1994. It is rated 125 psi max, and should blow 5-6 cfm at 90 psi w/no problem. That sounds like enough for the small jobs that I'll be doing.
    Has anyone else built or bought a blast cabinet recently?
    “Here’s to alcohol: the cause of, and solution to, all of life’s problems.” - Homer Simpson
  5. #35
    Studeman68's Avatar
    Join Date
    Nov 2015
    Location
    Michigan
    Posts
    572
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Tom S. View Post
    I have the same exact cabinet from TP Tools that Docdc posted a pic of earlier in this thread... Made in USA also and I love it. No leaks and top load...I bought the lower shelf/wheel kit for it when I bought it so it can me moved around easily...
    "The 2 most common elements found on Earth are Hydrogen and Stupidity"
  6. #36
    Senior Member
    Join Date
    Mar 2017
    Location
    Chelsea & Grayling Michigan
    Posts
    339
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Tom,
    I have access to the same TP tools cabinet. I tend to look at blast cabinets like gasoline containers, its bad when they leak.
    Nice looking cabinet you have there.
    So no answer for you from me,
    Steve
  7. #37
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,644
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Made this one 35 years ago still going strong. It will work fine with a compressor like yours but put a gauge on cabinet so when pressure drops you can stop and wait till it goes back up. Need to get a water desiccant filter or on humid days when compressor gets warm it will spit water drops. Mine will take mini frames except for the 14” speedway one I am working on now.
    Ole
  8. Thanks Tom S. thanked for this post
  9. #38
    owend's Avatar
    Join Date
    Feb 2010
    Location
    syracuse
    Posts
    3,346
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    My work went cheap and bought a pair from Harbor Freight, didn't work out so well or last either. They recently spent the money on new ones that were made in the USA and they are so much better for our needs. We use them all day for light to medium duty cleaning of parts.
  10. #39
    Senior Member Fantic Freddy's Avatar
    Join Date
    Jul 2016
    Location
    Macedonia, Ohio
    Posts
    852
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I got one of these gizmos the other day. It's built sturdy, has a magnetic base that sticks to my welding table. I'm no longer looking for a place to rest my MIG in between welds.FullSizeRender-24.jpg
  11. #40
    Join Date
    Jul 2016
    Location
    Macedonia, Ohio
    Posts
    852
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The above post has nothing to do with a blast cabinet, but I didn't think it was worthy of starting a new thread.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
