User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Senior Member
    Join Date
    Dec 2009
    Location
    north dakota
    Posts
    2,787
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    crank drilling guides !!!!!!
    Ok so we have new off the lathe crank drilling guides . For 5/16 - 24 or 18 . They are a 3 piece tool you start with the smaller hole one a 9/32 bit , and the body . Put on the end of the crank and it guilds the bit on center. Then you switch out the bushing to the larger one and run the tap in and it starts the tap on center and straight .20180211_111855.jpg
  2. #2
    Senior Member
    Join Date
    Dec 2009
    Location
    north dakota
    Posts
    2,787
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The parts of the guides
    The body and a guild bushing . I used one to tap and drill a crank on my briggs worked fine to drill and start the tap . I can run both the 18 and 24 thread in the bushing . So it will start both you can choose what you want to tap .these are 3/4 in crank guides im still looking for 3/4 to 5\8 bushings . A good stocked hardware store should have a plastic bushing . For a small cost ill try and get some but if i cant be aware these are 3/4 inch .
    I found putting a piece of tape around the end to hold the bushing in the body helped . But you can easy hold the guide in place with out it . The tape is running like the first pic .
    I got the 7 you see in the pic the cost on them is $24 shipped . Will do paypal , or money order .
  3. #3
    Senior Member
    Join Date
    Dec 2009
    Location
    north dakota
    Posts
    2,787
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    One gone so down to 6 . Get them while they are in stock
  4. #4
    owend's Avatar
    Join Date
    Feb 2010
    Location
    syracuse
    Posts
    3,349
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I got my bushings from McMaster Carr if I remember correctly. I think they were called, electrical sleeve washers?
  5. #5
    aarron's Avatar
    Join Date
    Oct 2008
    Location
    Central Ohio
    Posts
    359
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I assume you got my PM & payment on 2/12?
    Bonanza BC1300 (2), Bonanza BC1500SH, Lil' Indian (3), Skat Kitty, Rupp TT500, Benelli Dynamo, Benelli Buzzer, Taco T100, Gemini SST 80, Kawasaki MT1 75, Suzuki Trailhopper, Honda Z50, ItalJet Kit Kat, Allstate, Rupp Go Joe
  6. #6
    Senior Member
    Join Date
    Dec 2009
    Location
    north dakota
    Posts
    2,787
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by aarron View Post
    Yep sorry i did not get back to you they should be the mail tomorrow.
  7. #7
    Senior Member
    Join Date
    Dec 2009
    Location
    north dakota
    Posts
    2,787
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Down to 5
  8. #8
    aarron's Avatar
    Join Date
    Oct 2008
    Location
    Central Ohio
    Posts
    359
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Cool, thanks!
  9. #9
    Senior Member
    Join Date
    Dec 2009
    Location
    north dakota
    Posts
    2,787
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    And one more gets boxed to go for a ride . Bringing it to 4 left ....
  10. #10
    Senior Member
    Join Date
    Mar 2017
    Location
    Chelsea & Grayling Michigan
    Posts
    339
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    pm sent
Posting Permissions
  • You may not post replies
  • You may not edit your posts
