User Tag List
Thanks Thanks:  2
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Member
    Join Date
    Feb 2017
    Location
    Arizona
    Posts
    60
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Restore old sprocket
    Anyone know a good method to clean this sprocket up? (steel) WD40/Brake Cleaner/Degreasers only go so far. wire disc on a drill, or a solution to let it soak in for a few days?
  2. #2
    Fantic Freddy's Avatar
    Join Date
    Jul 2016
    Location
    Macedonia, Ohio
    Posts
    539
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    IMG_1001.JPG After a good cleaning with degreaser, I would hit it with this. Works good on painted surfaces too.
  3. Thanks KozmoK thanked for this post
  4. #3
    Senior Member
    Join Date
    Nov 2016
    Location
    Delphos, Oh
    Posts
    242
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Soak it in some vinegar.
  5. #4
    Member
    Join Date
    Feb 2017
    Location
    Arizona
    Posts
    60
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I currently have them (2 of them) soaking in home depots parts cleaner solvent in a 5 quart bucket and it seems to be brushing off after sitting for a few hours!
    Yeah!
  6. #5
    Senior Member neo71665's Avatar
    Join Date
    Jul 2016
    Location
    arkansas
    Posts
    902
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I go to the dollar store and buy the knock off (cheap) oven cleaner. It will strip grease and paint off steel and cast iron parts. It will work on aluminum but you have to watch it because it will eat the aluminum if left on it too long. If you have an anodized aluminum part it will remove the protective coat and color if it has it down to the bare base.
    When I have something I want to clean like new (car, truck, tractor, lawn mower, ect) I'll tear it all down and soak it in the oven cleaner. I then pressure wash it all and normally all that is left is the deepest rust. I then media blast it. If you reuse the media it helps keeping it from getting contaminated as fast.
    It is just like aircraft stripper (some mean stuff) so wear all the protective gear. I have chemical burn scars on my arms from being young, dumb, and bullet proof from the junk.
  7. #6
    Raskin's Avatar
    Join Date
    Jul 2016
    Location
    Florida
    Posts
    1,133
    Mentioned
    11 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I just paint mine black. the end..
  8. #7
    Member
    Join Date
    Feb 2017
    Location
    Arizona
    Posts
    60
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Got them cleaned! Thx guys for the input.
    I ended up just using some Brake Cleaner + parts cleaner solvent (home depot) in a bucket over night, and used a nylon wire brush.
  9. #8
    Join Date
    Jul 2016
    Location
    Macedonia, Ohio
    Posts
    539
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Looks good, get some rattle can clear (preferably gas/oil resistant), or just paint it silver to keep it looking like it does now.
  10. #9
    Senior Member BBQJOE's Avatar
    Join Date
    Jul 2016
    Location
    Arizona
    Posts
    421
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Send it off to get it chromed.
  11. Thanks buckeye thanked for this post
  12. #10
    Join Date
    Jul 2016
    Location
    Macedonia, Ohio
    Posts
    539
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Chrome IS cool, but you have to clean it all the time, to keep it cool.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
