User Tag List
Thanks Thanks:  7
Likes Likes:  0
Dislikes Dislikes:  0
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Senior Member Fantic Freddy's Avatar
    Join Date
    Jul 2016
    Location
    Macedonia, Ohio
    Posts
    830
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Muriatic Acid for cleaning rusty gas tanks. It can be harmful, so use safety gear. I coat inside the tank afterward with 2 stroke gas, because the bare metal will rust quickly before you refinish the outside of the tank. At the end of the day, I enjoy a glass of Jim Beam on ice.
  2. Thanks TheDullCarbide, FOMOGO thanked for this post
  3. #22
    Senior Member
    Join Date
    Sep 2017
    Location
    New jersey
    Posts
    209
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    IMG_1851.PNGCLR or Acid Bowl Cleaner
  4. #23
    Senior Member
    Join Date
    Dec 2017
    Location
    NC
    Posts
    205
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Denatured alcohol. Good for wiping things down. Tried cleaning roofing patch off of a trowel with brake cleaner, it hardly touched it. Next in line was gasoline, it dissolved the tar off in seconds. 30 wt oil. I keep some in old contact lens solution bottles around the shop. Perfect when you only need a drop or two to slick something up.
  5. #24
    Senior Member T-Town Mini's Avatar
    Join Date
    Oct 2011
    Location
    Tulsa, Oklahoma
    Posts
    992
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Tuff Stuff Multi-Purpose Foam Cleaner. This works great for cleaning everything in the shop.
    https://www.walmart.com/ip/Tuff-Stuf...22-oz/16817397
    It's not just for auto upholstery...it works on everything I've tried it on. It dissolves all the years old grime...spray it on maybe rub it in with a brush and, it actually wipes away.
  6. Thanks crazycarts4us thanked for this post
  7. #25
    Senior Member
    Join Date
    Dec 2017
    Location
    NC
    Posts
    205
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Anyone try 50/50 acetone/ATF for a rust breaker? I've been meaning to mix up a batch to try but always forget to pick up the acetone when I'm at the store...
  8. #26
    Senior Member Harquebus's Avatar
    Join Date
    Jun 2009
    Location
    Eastern TN
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by MJL View Post
    That is part of or the entirety of the "homebrew" recipe for Liquid Wrench aka penetrating fluid for rusty nuts and bolts. I'm lazy so I always buy the off-the-shelf aerosol concoctions--there's people who are utterly loyal to PB Blaster which I have yet to try...
    I doubt it has any rust removing qualities.
  9. #27
    Senior Member
    Join Date
    Mar 2017
    Location
    Chelsea & Grayling Michigan
    Posts
    275
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Yes, for years. It is fully head and shoulders above any others. I never mention it due to the flammable nature. I store it in a small, clean, dry glass bottle that pickled cocktail onions are sold in. Outdoor use only. And mix-up only what I need for a few days. Labeled appropriately as well.
    Gibbs is a distant second, followed by Kroil, another I can’t remember, then the pack.
    Hope this helps,
  10. #28
    Senior Member buckeye's Avatar
    Join Date
    Oct 2010
    Location
    L.A. Lower Alabama
    Posts
    30,891
    Mentioned
    20 Post(s)
    Tagged
    1 Thread(s)
    Rides
    When I lived in Texas, my favorite was the one that kept us up all night, playing Backgammon and drinking a case of beer.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
