User Tag List
Thanks Thanks:  3
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Join Date
    Oct 2011
    Location
    Henrietta, NY
    Posts
    1,061
    Mentioned
    8 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Hello,
    Factory Rupp specific jet numbers for the HS40 application
    C-1 needle
    # 38 idle jet
    #68 main jet.
    Regards,
    Joe
  2. #12
    Member
    Join Date
    Aug 2007
    Location
    Oak Grove, MN
    Posts
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The exhaust pipe "fasttony" is using is not the same as a factory B/W pipe. It does not have the bends in the same places, giving clearance for the carb to be in the OEM location. Looks like it will work just fine, but be careful that exhaust pipe gets very hot and can melt the plastic cable housing. It could cause the throttle cable to lock up from melted plastic. Just a precautionary note. I applaud anyone who does their own fab work.
  3. #13
    Member
    Join Date
    Oct 2009
    Posts
    99
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The throttle cable clears the exhaust pipe by 1", the fuel line is off from draining the tank.
  4. Thanks massacre, ruppking thanked for this post
Posting Permissions
  • You may not post replies
  • You may not edit your posts
