User Tag List
Thanks Thanks:  2
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Senior Member TWM1963's Avatar
    Join Date
    May 2018
    Location
    ohio 44851
    Posts
    189
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Motor engine mounting hardware?
    Suggestions on mounting hardware for mini bike motors engines? Bolts,nuts, washers???? I was going with 5/16 bolts washer and nylock nuts???
  2. #2
    Senior Member Doc1976's Avatar
    Join Date
    Mar 2014
    Location
    Arizona
    Posts
    200
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    5/16 is what I use. My suggestion would be serrated flange nuts, serrated flange bolts. I like to use grade 8 because I tend to torque the hell out of motor mounting bolts to ensure the motor doesn't move under throttle. I use flathead motors almost exclusively, and they tend to vibrate more than OHV motors, another reason I torque 'em.
  3. Thanks Havasu Dave thanked for this post
  4. #3
    Join Date
    Apr 2014
    Location
    MA
    Posts
    2,780
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    +1 on serrated flange nuts, I use them with bolts and lock washers
  5. #4
    Join Date
    May 2018
    Location
    ohio 44851
    Posts
    189
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Great idea! Thanks
  6. #5
    Join Date
    Apr 2014
    Location
    MA
    Posts
    2,780
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    They make serrated flange nuts with wider flanges that work great.
    You can also make mounting plates but that is a little more involved. I made some for my drag bike just so I could use 1 hand to remove engine bolts since I have jackshaft plate under engine.
  7. Thanks TWM1963 thanked for this post
  8. #6
    Member I74's Avatar
    Join Date
    Jun 2018
    Location
    Cedar Rapids Iowa
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Nice hardware, massacre !!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
