User Tag List
Thanks Thanks:  1
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Senior Member Sprocket86's Avatar
    Join Date
    May 2010
    Location
    London, Ontario, Canada
    Posts
    511
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Not so mini bike View Post
    I have one of those mufflers that's on the hs50. Mine was on a NOS engine as well.
    I wonder what equipment application requires the use of these end vent mufflers? The engine must be situated in a way where the standard dogleg muffler would emit the exhaust towards the operator.
    I think it's cool that it still retains the factory paint and has yet to be burned off. These are the Tecumseh mufflers that you would see years down the road all completely rusted and in some cases, rotted out.
    The newer engines that are raw from the factory with no paint on the block(90's and 2000's) have a galvanized like mufflers and seem to last forever.
  2. #12
    Join Date
    May 2010
    Location
    Posts
    511
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Can anyone tell from this pic and the ID numbers if this H35 has a Ball Bearing PTO and a iron cylinder?
  3. #13
    capguncowboy's Avatar
    Join Date
    Apr 2014
    Location
    Bluff City, TN
    Posts
    5,504
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    https://www.partstree.com/parts/tecu...-parts-list-1/
    Looks like a bushing PTO, not a bearing. Not sure about the bore, but I doubt it's steel sleeved due to the year
    I'm not afraid of death. I'm afraid of dying. I want to go peacefully in my sleep like my father did -- not like his screaming passengers
  4. #14
    Senior Member markus's Avatar
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    10,194
    Mentioned
    15 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Its ball bearing crank, not a steel sleeved block. They used that 3.5 muffler in industrial/equipment application as well, I have the mate to that engine in crapsman stampings and colors off a yard vac. came with the same muffler and BB crank so I bought it to steal the parts from.
  5. #15
    Join Date
    May 2010
    Location
    Posts
    511
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by markus View Post
    Thank you markus
    I might end up using this H35 with a Comet Tav2 due to the fact that it has a ball bearing PTO. The axial load placed on the crankshaft when the belt is engaged would be pretty high I would imagine.
  6. #16
    Join Date
    May 2010
    Location
    Posts
    511
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by capguncowboy View Post
    I had my doubts it being a steel sleeved block, I don't think I've ever seen a small frame Tecumseh with a steel sleeve.
    Either way I'm very happy that I found this engine.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
