User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Junior Member
    Join Date
    Mar 2015
    Location
    Wichita KS
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Tecumseh H35 engine crankshaft blues
    Hi all,
    I am trying to rebuild my 1971 Tecumseh H35-45348H engine. Upon taking it apart I found the flywheel was loose on the crankshaft damaging both the crank keyway and flywheel. Some years ago I purchased what was supposed to be a NOS Rupp H35 crank. I pulled it off the shelf and looked it over. One I don't think its NOS and two the rod journal is about .851 inches in dia, way under size.
    Does anyone have an idea of what this crank might be for, it has the 3 inch snoot?
    Since the proper 33085 crank seems to be rare as hens teeth will a Rupp Tecumseh HS40 crank work. I know it has a larger crank journal?
    Does anyone know of a good machine shop that can bore these engines out, since the block is some sort of aluminum alloy I think it takes a special technique?
    Thanks,
    Bill T.
  2. #2
    Senior Member
    Join Date
    Oct 2015
    Location
    PA
    Posts
    368
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    markus on here should have all of that information to help you.
  3. #3
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    11,394
    Mentioned
    50 Post(s)
    Tagged
    1 Thread(s)
    Rides
    Lil Indian, Ruttman, DB30, Warrior, lil Bill, EZ Rider, Savage SSC , Powell, BONANZA
  4. #4
    Junior Member
    Join Date
    Mar 2015
    Location
    Wichita KS
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Anyone have the specs on the 32555b crankshaft?
  5. #5
    capguncowboy's Avatar
    Join Date
    Apr 2014
    Location
    Bluff City, TN
    Posts
    5,784
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by wthanel View Post
    I have one that's in pretty good shape, includes the breaker cam and flywheel nut too.
    Mini Bike Tecumseh Engine 3.5HP H35 Crankshaft 32555B Rupp Bonanza Tapped Keyed | eBay
    The rod journal on mine is .86 ", crank is 2-1/4" x 3/4", tapped and keyed
    I'm not afraid of death. I'm afraid of dying. I want to go peacefully in my sleep like my father did -- not like his screaming passengers
  6. #6
    Junior Member
    Join Date
    Mar 2015
    Location
    Wichita KS
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I have purchased what I think is a proper 3 inch PTO crankshaft off of Ebay, time will tell once it gets here.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
