User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 3 of 3
  1. #1
    Senior Member Fisher1983's Avatar
    Join Date
    Sep 2013
    Location
    Michigan
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    HSSK50 exhaust flange??
    I've been researching header flanges for my HSSK50 (1994) and have come up with nothing except a vintage flange that uses screw in pipe. The issue started when I went to get gaskets at the mower shop...the exhaust gasket is wrong. It's for an H50...the bolt holes are centered with the I.D. of the gasket. My HSSK50 has bolt holes that are off-center to the port I.D. (think Honda or clone.) So....does anyone make header flanges that will fit the HSSK50? I don't want to spend stupid $$ on a vintage part only to modify it for my needs. Thanks for any help!
  2. #2
    Member Oldschoolcool's Avatar
    Join Date
    Feb 2017
    Location
    Northwest Ohio
    Posts
    57
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I have the offset exhaust flange on my B and C series HS50 as well. I ordered the correct exhaust gasket off of ebay. The header that I ordered from OMB has the offset bolt pattern flange also. I would think that header would work on the HSSK50 too.
  3. #3
    Join Date
    Sep 2013
    Location
    Michigan
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thanks for the input. The OMB header didn't have pics of the flange area.... A fellow OMB member offered to build a header for me. We will see what he comes up with! Any others, please feel free to share info.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
