User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 8 of 8
Thread: Id help
  1. #1
    Member
    Join Date
    Aug 2017
    Location
    wisconsin
    Posts
    72
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Id help
    Hi Guys,
    I picked up a Tecumseh that is supposed to be a 60's era H60. It has the tin tag on the blower/starter cover but the tag does not say H anything. Heres the numbers off the tag.
    Model 143-586222
    Serial 9260 07565
    What is it? And where can I get a gasket set for it?
    Thank you,
    Jeff
  2. #2
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    3,443
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    https://www.searspartsdirect.com/mod...7/1503500.html
    Michael
    Edit: That is an H60 Tecumseh
  3. #3
    Member
    Join Date
    Aug 2017
    Location
    wisconsin
    Posts
    72
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thank you Michael. Any idea of the year?
  4. #4
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    3,443
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by older then dirt View Post
    Post some photos of it.
    Michael
  5. #5
    Member
    Join Date
    Aug 2017
    Location
    wisconsin
    Posts
    72
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Fantic Freddy's Avatar
    Join Date
    Jul 2016
    Location
    Macedonia, Ohio
    Posts
    640
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I would guess early 70's or so, off of a snowblower.
  7. #7
    Senior Member markus's Avatar
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    10,560
    Mentioned
    38 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The numbers you posted would make (the tag at least) from a 1969, I would urge you to closely measure the bore and stroke if you pop the head off though...before ordering anything more than a gasket set. I have a suspicion that block does not match that tag number. Did they use textured paint on the shroud?
  8. #8
    Member
    Join Date
    Aug 2017
    Location
    wisconsin
    Posts
    72
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thanks Freddy and Markus
    The shroud was either sand blasted or soda blasted. The texture look is pitting from rust. I'll be addressing that when I repaint. I pulled the head when it arrived. The bore looks pretty nice with cross hatching still visible. I will wait for a new head gasket to check compression numbers. Given the rust pitting and the non drilled crank I guess snowblower engine would make sense. I have a old Rupp roadster frame that has been in my shed for a few years. I'm going to use this with that frame to make a Rupp rat bike. After building the Black Widow, It's just to expensive to do another proper Rupp restoration.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
