User Tag List
Thanks Thanks:  1
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Senior Member Rupp 72's Avatar
    Join Date
    Oct 2011
    Location
    Wisconsin
    Posts
    835
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Building a high performance HS40!
    Rebuliding an HS40 for a Black Widow, but hopefully with a bit more performance. I had the cylinder bored .080" oversize, and nickel silicon carbide plated cylinder wall. Pair that with a Wiseco piston and an ARC billet aluminum connecting rod. Also have a latter model EZ-Pull cam that should have a few thousandths more lift that original. I'm excited to see how it turns out!
  2. #2
    Join Date
    Aug 2016
    Location
    White Lake , Michigan
    Posts
    1,751
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I think if you "port" the block to get rid of the sharp edges in both the intake and exhaust passages you would gain a little flow and power.
    Looks like an interesting build. Keep us posted.
    Danford1
    Time is the best teacher. Unfortunately it kills all of its students.
  3. #3
    delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    6,503
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    nice nate, thats a Big Hole.
    i think you will like the end result.....
  4. #4
    Join Date
    Oct 2011
    Location
    Wisconsin
    Posts
    835
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I think I'll give the porting a try Danford. And thanks Brian for all of your help up to this point! Can't wait to start putting it back together
  5. #5
    Senior Member markus's Avatar
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    10,626
    Mentioned
    42 Post(s)
    Tagged
    0 Thread(s)
    Rides
    nice! I had one of the wiseco .080 over piston/rings awhile back but sold it off, In hindsight I should have kept it because I ended up with a few blocks with really trashed out bores but great shape everywhere else How bad on the wallet is the plating to have done?
  6. #6
    chatten63's Avatar
    Join Date
    Jun 2010
    Location
    Beloit,Wi.
    Posts
    3,171
    Mentioned
    26 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Nate. Who did the nickel silicone plating for you. I am doing one also being bored out .080.
  7. #7
    Senior Member
    Join Date
    Oct 2011
    Location
    Henrietta, NY
    Posts
    684
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I am interested in the plater as well. I have a few HS40 blocks. One of them destined for a Blackwidow build.
    Keep us posted with detail please.
    Regards,
    Joe51
  8. #8
    delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    6,503
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    guys, the place i sent nate to have is plating done was a company in plymouth wis called millennium technologies. i found this place last year in doing my research to have this process done on my ohh-build. they are one of the only companys that i found that can do this to a small engine. they also call this a blind boring process where it makes it harder for most companys to do the plating correct. need correct equipment for this type of plating and they had it.....
  9. #9
    chatten63's Avatar
    Join Date
    Jun 2010
    Location
    Beloit,Wi.
    Posts
    3,171
    Mentioned
    26 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by delray View Post
    So this place bores the block to the piston and then they plate it
  10. #10
    delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    6,503
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    yes rick,they bore the block and then plate it and then hone it to piston size....
    sometimes the plating will vary in thickness. that will depend on what's going on with the block. for example poor aluminum casting.
    it may take more plating to bond correctly. good thing with tecumseh's the casting is good...
    i believe my plating only has about .005 to .006 and from the looks of nate's maybe the same. they say the surface wear is stronger then cast iron sleeve and you will wear out the rings before the plating. i think it's a great process for something like nate is doing and for that type of piston and rings he is using or for any racing application.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
