User Tag List
Thanks Thanks:  15
Likes Likes:  0
Dislikes Dislikes:  0
Page 8 of 9 FirstFirst 123456789 LastLast
Results 71 to 80 of 86
  1. #71
    Senior Member
    Join Date
    Jan 2018
    Location
    Michigan
    Posts
    564
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I have a dellorto ub22 on an HS50 tecumseh motor for an mtd. I don’t know what the jetting is though, it’s running what came with it. But it works very well. I don’t really notice a huge difference between it and the Ua19. I do know that the ub22 chews a lot more gas though, it’s hangry.
  2. #72
    Senior Member Rupp 72's Avatar
    Join Date
    Oct 2011
    Location
    Wisconsin
    Posts
    884
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Ajf View Post
    Rupp used the mb22a as an upgrade on the 68-69 h50 bikes, they also had a performance exhaust. They also used it again as an upgrade on the ss-5 and it was originally going to be factory but ended up an option. There were no internal upgrades from rupp directly. I have some stuff on my phone from the rupp parts manual. I have more literature but I need to find. It is well known that rupp used the mb22a if you do a search there is lots of discussion on itAttachment 107907Attachment 107908Attachment 107909
    I truly don't think Rupp ever used the MB22A on the SS-5, not even as an option. I have tried to install my MB22A onto my SS-5 and it doesn't fit. The carb hits the bottom of the gas tank. I think the intention was to use it on the SS-5 but i don't believe rupp ever actually did. During the time this bike was being developed was also during the same time minibikes were being phased out and rupp was going bankrupt. I have a feeling this performance upgrade was comprimized just to get the bike in production and on the market in an effort to stay afloat. I have seen many SS-5 bikes and none that I have seen have had a MB22A on them. There is the only picture I found on the internet that does have a MB22A on it but it appears to have a special intake that drops the carb down so it fits. I am not certain this is the case, it potentially could have been a option, but I haven't ever seen prof of that.
    Quote Originally Posted by delray View Post
    yes Ajf I am aware of the 22 up grades on the TT500's . I personally never seen any info printed from rupp using the 22 as a up grade on the ss-5 bike. that would be nice to see if you have any info on the ss-5 bike using this...
    @Rupp 72 had posted the dealer spec sheet for the ss5 awhile back but the photo is now missing from the thread. I have one I need to locate but maybe he will see this and repost his photo.
    Notice the note at the bottom of the page! *** "At time of publication engine specifications were not firm and may be different on production units" ***
    So yes, I think the intention was to use the high performance MB22A carb, weather or not they did at all, still can't be certain?
  3. #73
    Senior Member delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    7,026
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Rides
    thanks nate for posting that info...
    was this maybe the other bike you seen with the carb on it. note too it is mounted different from the brochure. I think this was a custom mod on this bike.
    that bike looks bad ass. I would have a hay day with that hs-50 motor. make it go like you where riding a 125+ dirt bike......
  4. #74
    Senior Member
    Join Date
    Jan 2018
    Location
    Michigan
    Posts
    564
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Got some the new toys set up and ready for installation.
    a Dellorto ua18s and the Dellorto/Lambretta 19mm are ready
    for motors. i have to finish up some bikes to put them on
    though...
    Also regarding the Dellorto ub22s, this picture was posted earlier, but here it is on my MTD.
  5. #75
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    7,026
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Rides
    cfh,how close is the cable to the exhaust with that 22mm pointing straight up.
  6. #76
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,746
    Mentioned
    22 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Those delorto's are such pretty carbs, look great on the Tecumseh.
    Ole
  7. #77
    Senior Member
    Join Date
    Jan 2018
    Location
    Michigan
    Posts
    564
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    on the throttle cable... that's why i generally put in those aluminum block spacers, to get the cable away form the exhaust. but on the Dellorto ub22 the cable isn't near the exhaust. it looks like it is, but it really is not.
  8. #78
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    7,026
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Rides
    couple things that look interesting on that ss-5 brochure. bike is a lighted coil/headlight setup. I never seen a lighted coil model before and the other thing was the horse power rating. they have that hs-50 rate at 6hp. got to be rated with the header and dellorto carb?
  9. #79
    Join Date
    Oct 2011
    Location
    Wisconsin
    Posts
    884
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    This bike has a UA19S carb. Not an MB22a carb on it which is why it fits. Two totally different style carburetors.
  10. #80
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    7,026
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Rides
    yes nate, the original rupp 19mm dellorto can mount side ways because of the bowl mount they use. will a 19mm bowl still work on a 22mm.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
