User Tag List
Thanks Thanks:  15
Likes Likes:  0
Dislikes Dislikes:  0
Page 9 of 9 FirstFirst 123456789
Results 81 to 85 of 85
  1. #81
    Senior Member Rupp 72's Avatar
    Join Date
    Oct 2011
    Location
    Wisconsin
    Posts
    884
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    No i will not. The 22 doesn't have a detachable bowl, it is all cast as one piece unlike the 19.
  2. #82
    Senior Member delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    7,024
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Rupp 72 View Post
    are you sure on that nate?
    cfh posted a 22 with the detachable bowl.
    also ruppking specified the high speed adjustable jet assembly parts will fit any UA or UB series carbs.
    https://www.oldminibikes.com/forum/m...onversion.html
  3. #83
    Ajf's Avatar
    Join Date
    Oct 2013
    Location
    Akron Ohio
    Posts
    1,149
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by delray View Post
    I believe Rupp72 was referring to the mb22a dellorto that was going to be used on the ss5. The mb22a is a one piece carb.
  4. #84
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    7,024
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Rides
    yes I did wonder little about that. the carb cfh had was a ub. with a ub carb you could make it work if there was a clearance problem.
    weird how the brochure shows a dellorto carb mounted up close to the block, but rupp72 said he had a clearance issue trying to mount it like that. nice if rupp had a better picture of that in there brochures.
  5. #85
    Senior Member
    Join Date
    Jan 2018
    Location
    Michigan
    Posts
    560
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Does anyone know how to decipher the Dellorto letters? for example, UA versus UB versus MB for the prefix. And after the carb size in mm, the suffix like S or S2... ?
    Prefixes:
    Ua
    Ub
    Ubf
    Ma
    Suffixes:
    S
    S2
    Bs
    D
Posting Permissions
  • You may not post replies
  • You may not edit your posts
