User Tag List
Thanks Thanks:  3
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 9 of 9
Thread: need hs-40 help
  1. #1
    Senior Member colt 1911's Avatar
    Join Date
    Mar 2017
    Location
    stewartstown pa
    Posts
    140
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    need hs-40 help
    i have a hs-40 that is missing the engine tag that was held on with the 2 rivets- it has points and the exhaust port is minus the 1/2 inch threads- i would like to replace the piston rings- would someone tell me a engine part number that i can use to order parts? thanks Jeff
  2. #2
    Havasu Dave's Avatar
    Join Date
    Jul 2012
    Location
    Lake Havasu, AZ
    Posts
    9,130
    Mentioned
    29 Post(s)
    Tagged
    0 Thread(s)
    Rides
    HS40-55513F is a points engine. Bores were the same for the HS40s. Cams were changed, as was the ignition as you mentioned, but the rest should be the same for all of them. You might try and get some .010 over rings if you've honed it, then file end gap to specs. They tend to run wider end gaps on factory ring sizes.
  3. Thanks massacre thanked for this post
  4. #3
    Senior Member markus's Avatar
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    11,224
    Mentioned
    84 Post(s)
    Tagged
    1 Thread(s)
    Rides
    Quote Originally Posted by colt 1911 View Post
    Might want to make positive it is an HS40 block before ordering anything HS40, The only way you get one of those with no 1/2" NPT threads in the exhaust if theyare machined out or busted out by a header.
  5. #4
    Join Date
    Mar 2017
    Location
    stewartstown pa
    Posts
    140
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    thanks guys- i thought it was strange not seeing the threads- all my previous engines were threaded- i am currently building another known hs-40- could i compare the cylinder diameter?
  6. #5
    Join Date
    Jul 2012
    Location
    Lake Havasu, AZ
    Posts
    9,130
    Mentioned
    29 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Bores for points engines:
    2.8120 HS 50
    2.6250 HS 40
    2.5000 H35, H40
  7. Thanks massacre, manchester1 thanked for this post
  8. #6
    Join Date
    Mar 2017
    Location
    stewartstown pa
    Posts
    140
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    i have a parts break down for a 55513E from 1978 that i can use- thanks
  9. #7
    Join Date
    Mar 2017
    Location
    stewartstown pa
    Posts
    140
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    what was the last year for the id tag with the 2 rivets?
  10. #8
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    11,224
    Mentioned
    84 Post(s)
    Tagged
    1 Thread(s)
    Rides
    They were transitioning them out in 1974 and going to the stamped on top style, you could find some engines to still be the old style shrouds and small aluminum flywheel but stamped on the top up near the headbolts, no id tag though (but the holes were there for them). Not as much for the HS40 as they were able to transition them pretty fast to the squaretop shroud since the HS50 flywheels fit those, but the smal H engines were drug out into 1975 til they got the steel flywheel worked out for them.
    you can see how they stamped the curved shrouds on this 1974 JC penney Duster Chopper I once had:
  11. #9
    Join Date
    Mar 2017
    Location
    stewartstown pa
    Posts
    140
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    thanks Markus
Posting Permissions
  • You may not post replies
  • You may not edit your posts
