User Tag List
Thanks Thanks:  30
Likes Likes:  0
Dislikes Dislikes:  0
Page 7 of 7 FirstFirst 1234567
Results 61 to 67 of 67
Thread: OMB Shop Notes
  1. #61
    KustomKartKid's Avatar
    Join Date
    Jul 2010
    Location
    Central New Jersey
    Posts
    16,373
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Just something I was thinking of as I was posting these pics in another thread:
    If you own a band saw and have ever tried to push round stock into it you will find out in a hurry that it can put a hurting on you. You may think you can hold it from spinning...but chances are that it's going to grab and spin and when it does it will pull your fingers under and flatten them like a little steam roller.
    I found the best way to hold smaller stock is with a little machinist vise like this Palmgren:
    These are really great little vises because they are machined flat or square on 5 sides so you can accurately hold parts and material parallel or perpendicular to your saw, drill press, grinder, mill, etc... And always use a push stick if you want to keep all your fingers.
  2. Thanks massacre thanked for this post
  3. #62
    Senior Member jpdriver1's Avatar
    Join Date
    Oct 2010
    Location
    Garden Grove, Ca
    Posts
    152
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    found these for download
    Popular Mechanics Shop Notes
  4. #63
    Member
    Join Date
    Apr 2017
    Location
    Eastern Kentucky
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    A two stroke engine is a simple beast. So long as it has gas spark and compression it's operable. But if there is the tiniest air leak they are NOT happy. I found this on a scooter forum. Build a leak down tester. Using a pump bulb from a BP meter(sphygmomanometer) and a LOW pressure gauge and some pipe and a rubber plug or rubber plate to block the exhaust and a rubber plug big enough to be TIGHT in the intake. Assemble it in a manner where u can pump the air into the engine and measure the pressure. A healthy two stroke should happily hold five to six lbs of pressure. Pump it up, and walk away for a smoke or half a beer (10 minutez) if the gauge has moved u know u have a leak. Of course a running motor is easy to check for. aleak. A fresh build on ur bench, not so much.
  5. #64
    Member
    Join Date
    Apr 2017
    Location
    Eastern Kentucky
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    One more thing. Rings, a PITA to install without a ring tool. I have a way that may sound unorthodox but it does work.
    Take a piece of scrap extension cord, strip the rubber insulation, separate ONE or TWO strands. Wrap it or them around the rings and pull the wire tight enough to compress the rings twist it then snip it close as possible to the ring Now this is the strange part. Assemble the engine leaving the wire in place. It will burn off and melt on first start, coating that ecylinder with a very faint copper coating. Not major thick, but still it's there. I actually read this tip in the classic novel, " The Grapes of Wrath". I didn't believe it so I tried it just for kicks. IT WORKS!!!!
  6. #65
    Senior Member
    Join Date
    May 2017
    Location
    arizona
    Posts
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Sometimes for a phillips head screw that slips, you can take a new or at least in very good shape phillips bit and hammer it into the damaged screw. It often will give it enough bite to remove it. If the bit shows any signs of wear it is junk. Get a new one. If it spins on the screw it is ruined so don't let it spin. Make sure the bit is at a 90 degree angle to the head. Use the right size phillips bit. I am amazed at how many do not know that there are several sizes of phillips. Typically you will find number 1,2,and 3. On rare occasions you will find a Reed/Prince headed screw. looks like a phillips, but isn't. It will have stamped slash marks on the head between the cross marks. Need to use a Reed/ Prince bit. Worse case on a stubborn screw is to drill it out with a left handed drill bit. Often the heat and the left hand turning bit will back it out.
  7. #66
    Senior Member Dodgeboydan's Avatar
    Join Date
    Dec 2011
    Location
    Clinton, Ohio
    Posts
    265
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I use pieces of guitar and piano strings to clean out carburetor jets and passages
  8. Thanks massacre thanked for this post
  9. #67
    Senior Member EVOL Tweety Bird's Avatar
    Join Date
    Sep 2017
    Location
    Lakeland Florida
    Posts
    594
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by jim85541 View Post
    Another one to add, JIS screws. Japanese Industrial Standard, use a regular Phillips on these and you'll strip the head.
    Anywho, my tip. Working on anything that has say a small E or C clip Put the part inside a large Zip lock bag when disassembling or reassembling. That way when the said clip goes flying off, the bag will catch it, and you won't spend the rest of the day looking for it.
  10. Thanks massacre, jim85541 thanked for this post
Posting Permissions
  • You may not post replies
  • You may not edit your posts
