Someone aready posted about band brakes and I learned a lot, but I had a question?
I'm running a #35 Chain 11 Tooth 5/8" Bore Max Torque clutch that measures 4 3/16" across. Do I order the 4-3/16" Brake band with bracket - Manco Part #1036 (4-3/16" BRAKE BAND W/BRACKET) or the larger
4.5" Band Brake - AZ2255 (4.5" band brake).
I want to make sure that I order the correct one the first time. I'm not sure if I need to order the next size up so it fits over the clutch or do I order the same size as the clutch?
Any help would be appreciated
