You have to use the parts that comes with the champion rocker set...
Setting the lash is super easy with these rockers...
As far as changing anything on a BSP engine...probably the stock springs, as they will float earlier with the heavier rocker arms.
Other than that, did you get the taller valve cover? Or,a spacer for the valve cover, or massage the stock cover to accept the new taller rocker arms?
