What is the deal with the inlet on new carbs? Can they in fact be turned to better accommodate the fuel line? Ive heard you cant and ive seen manuals saying how to do it. The inlet on this carb sure would be better if it was straight up. If I can move it can I just turn it up or do I have to...
Here it tis...sounds awesome, but dumps fuel out of the bottom overflow AND seems to run better without the mikuni fuel pump (Gravity feed). Is this the case with a mikuni flatslide? Is there a workaround for a karting/atv application requiring a fuel pump? Thanks
My computer is old,i have a new one and want to hook it up.Here's the question,will my new computer be unrecognized when i log in? Is a new account needed?Will i no longer be roccosbike? Please help with this because i am unsure of computer procedures, Thank You.
Hi,
First post and first question.
I ordered some new tires and received them today.
The size is 4.10/3.50-6
The new Carlisles only show 4.10-6 and are considerably narrower than my original tires. Which are the original Goodyear tires that are probably from the early 70's.
Should I return...
Hey, new to this forum. My name is Daniel. I purchased a 49cc mini chopper for $40. Brought it home and it fired right up and rode it around for 2 days. Well the pull start cord broke which wasn't a big deal, until my friend tried to start it with a impact gun. He broke the long bolt behind the...
I'm working on finishing the custom fiberglass underseat tank for the "mystery bike". Sunday I flushed it out and let dry , yesterday I caswell'ed the interior and unless I head to north Florida this week to do some "picking" I would like to try and get it prepped for paint. it was not in the...
Hey everyone I'm planning to buy the 6.5hp engine off of OldMiniBikes for 135 bucks. How much better is the aluminum flywheel than the steel? Will the steel flywheel be strong enough to be safe with that engine or should I go ahead and get the aluminum?
Sent from my LG-P930 using Tapatalk 2
Hey guys I wanna throw something by you.
A few months ago I rebuilt my car engine, new pistons rings decked the head cut valves. ported and polished with a port Match, lighter crank and flywheel. Any way it ran great but I forgot the check the main bearing and it trashed my crank and all...
I got my 81 honda c70 back with a toasted top end.
I looked into this kit and dratv says I can use the newer e22 head or my stock head.
88cc_CYLINDER_KIT C70_1970_to_1981 Z50'S_69_TO_81
But I was wondering why cant I use the e22 head on the stock jug ?
The reason I ask is because the e22...
I have a 1962 Tote Gote 670 Nova with the climb away cvt clutch.
Problem ware do i get a new drive belt ?
The orignal says : Dayco / Bonham 4- 7079 3H
Best i can measure it is 23"x.750 wide.
There is a Tote Gote parts website that sells them for $44.00 but there the wrong size. I...
I have a Baja warrior with the 6.5 homelite engine.it quit so I bought a gx200. My question is how can I hook up the head light? The homelite has a plug commin out of the block. The gx has a kill switch there. Any ideas?
Found this on cl, said 3hp briggs & stratton $20.00. It was still there a few days later. So I called the guy and asked if he would take $10.00 for it? He said yes and there you go something I need and get. I need help though. What do I need to rebuild carb.? I mean in the way of gaskets and...
I have several questions I would like to ask.
1.What is the best Torque Converter that I can purchase.
2.Is there any beneficial value to a adding straight pipe to a mini bike(I have the Baja MB200 Mini Bike).
3. Should I purchase an new air filter?
I'm in the process of doing an engine swap on my K&S Hornet. My problem is that the shaft on the new motor is smaller than on the old one and the clutch won't fit.
Is there a bushing or sleeve I can get so as to be able to use the original clutch on the smaller shaft or am I stuck buying a...
I have a question about the different Baja MB series. Is there a difference other than colors? MB165 MB200 STYLE? Warrior,Heat,Mini Baja? Ect. Are the frames all the same? I am looking for the beefiest one they make. The one that will hold up the best to an old fat guy... I will put on the TAV...
