I got a db30 an I want to switch the kickstand to the other side an lower the fenders my dad said I'm gonna take away from the original look of the bike what do you guys think should i move the kickstand or leave it where it is an what about the fenders thanks....:shrug:
I have a Subaru 7hp engine that I would like to modify a little bit. My question is...if I put a header and K&N type air filter on it, will I have to modify anything in the carb to make it run well or will it run well with just the filter and exhaust changed??
Thanks.
Restoring a super bronc...got everything except original engine..going to replace with new lh358xa-34-adj...my ? Is will the original comet clutch braket that the pulley and band brake set up bolt to the newer lh358xa-34-adj motor....any help would be kool...I'm pretty good with the hondas and...
Has anyone experimented with omitting one of the two compression rings on the old aluminum bore flatheads?
Im just kicking around the idea, to see what happens to bore life.
I have disassembled quite a few of these old engines, and noticed the vast amount of carbon build up usually stops at...
Alright, I've been searching the forums and these are the parts that I've come up with.
My question is will these work together on my new, otherwise stock, 212 Predator, and do I need anything else for it to work/run correctly? Besides longer carb studs that is. Told you I'd been...
First, I did try searching. I found some stuff but I just don't understand fully which type of sprocket I need..
So I ran through all the sprocket calculators, The Baja mini has stock a 10T clutch, a 20T jackshaft and a 10T jackshaft and a 50T rear.
I want to change the 10T sprocket on the...
I am building a wanna be mini drag bike, and have set up the front to accept a rim and tire off a pocket bike the rim is an 8" tri spoke and the tire size is 90x65x8 I used this because even the disc brake was pretty much a bolt on for the trail horse frame that I flipped and stretched...can...
I have a line on 2 Harley 65cc minibikes. One is pretty complete but the fork tubes are bent. The other is a donor bike. Forks might be OK on this one. My question is how hard is it to find parts for these? I should be able to get them both for about 200 bucks, but I don't want to buy them...
Ok just got a quick clone question. New to all this,but the blue (Greyhound Harbor Freight 6.5hp) engine is a clone, I get it. But is it a clone of a Honda Gx 160, or a Honda Gx 200 ?? Might be a dumb question but,ur helps appreciated,thanks!!
ok I just picked up a damn good running 5hp flatty on alky cheap..after further examining (when I brought it home) I noticed someone poorly tried to re-drill one of the carb to block bolt areas...
now for the odd question..I've heard of some engine builders "welding" up the valve area inside...
Bought this minibike with a gx160 on it. Will my gx390 bolt right onto it?
i have a 36mm keihin carb on the side, is that too big for the gx390?
where can i get jets for that carb?
Where can i get an intake manifold and spigot for the gx390?
What clutch could i use? Im just gna use it to...
Tecumseh Go kart parts engine lawn mower mini bikes - eBay (item 220735887760 end time Feb-13-11 15:42:39 PST)
Please contact me, I have a question for you in regards to the sale...seems I have a problem with this seller.
Oooooh....Evil Post !!!
I picked up a Bird 'Falcon' recently that has a factory-installed Comet 2-speed jackshaft...
I've never seen a Falcon with a 2-speed before...anyone have any info?
Hi guys I have the same model keyston as in this picture .. I want to purchase new srpings for the front forks... all three..... who carries this kind of thing .. ?
Just a quick question about the choke setup on this style Pulsa Jet carb.
I have numerous slide choke carbed motors. (and I really like them) But I have no experience with this newer fixed jet and style of choke and was wondering if this is all there is to it or ? Is there a linkage that...
I pulled the side cover off of my 5hp briggs as I need to lengthen the snout on my crankshaft... and I noticed that the dot on the crank does not line up with the dot on the cam.
The crank is the type with a roller bearing on the side cover side, so there is a "o" stamped in it on the throw...
Does anyone know the size of the rear sprocket on the stock jackshaft assembly of a baja warrior? This is the small "driven" sprocket, not the driver, I'd like to know the inner diameter and the number of teeth if anyone knows that off hand?
