Hi Guys, what is the main difference between the 2 engines ? What parts will swap and what parts wont ? I have a 196 and want to do some upgrades. Thanks, Dil
16 CC's bigger bore and stroke. there are a few different versions of the 212 some share parts with the 196 HF engines and some share less. The Rod for the 212 is different than the rod for the 196. The Hemi version of the 212 can use same cam as the 196 but some of the others have a slightly larger bearing diameter on the cam. Some of the 212's have larger valves and some are 5mm stems vs 5.5 on the 196.
