I would believe after reading your post on the snowmobile site and reading this by Installing your .125 shims under the springs Especially the ex.with its oil seal shim You have succeeded in Probably causing Coil Bind or at least near.....You have increased load on camshaft exponentially,Resulting in your cam Failure,At this point I think since you need a cam anyway I would look at a MOD2 From Dyno Cams,possibly have them grind in 4* advance They are a proven torque cam, approx
$ 55.00 I have used many,When getting a cam for these Clones It is WISE to measure the Bearing Journal Dia. as there are 2 Diff. sizes......550+or-a thou &.558+or- another Thou. And the lift is close to stock so no worry about clearance issues
I think you would be pleased with the results.Also check pushrods for straightness and rockers and hardware for unusual wear you may have caused! Put It back together and let your kid have fun before spring.....Dave...... By the way..... Also they have gaskets, you just have to figure out if they are clone or predator style on sidecover I believe the # is 1304 or 1304 P Go to their website Dynocams.com :laugh: :smile: :thumbsup: Also I Don't believe on a sled you will reach Explosion RPM @least not your son!!!!
