My setup below. I'm having problems with my 22mm mikuni carb. It only wants to run with the enricher open ("choke" on). It starts on the second pull with the choke on and idles great, when I turn it off it dies, even when warm. I can idle it up with the idle screw for the slide and make it idle with the choke off, but when the choke is on with the idle screw in the same spot it idles crazy high. I have a 12.5 and 130 jets with the clip in the center notch. I don't know what's going on with it. Any help will be much appreciated.
-non hemi predator 212
-billet rod and flywheel.
-nrracing ported 18cc Honda head milled .050
-SS valves and 26lb springs
-cm push rods
-champion rocker arms
-.016 copper head gasket
-lash caps
-black mamba sr. cam
-head and side cover studs
-22mm mikuni with long intake and k&n style filter
-Robertson torque tube 3 stage header
-cm push rods
-lash caps
