1986 3HP briggs model 82322. Dumped a little gas in the carb and turned it over with an electric drill and socket on the overriding clutch.
When the thing fired everything spinning would stop right now. Once I got it to run but it would not do it again. Just the stop thing.
Pulled the flywheel and the key was OK. So I lapped the flywheel to the crank and tightened the clutch with an air chisel holding the flywheel with my hand. I sanded some rust off the flywheel surface which passes the magneto.
Put the shroud back on and it started working. What was wrong with it ?
After that I cleaned the carb and gas tank. It is running well.
3v0
3v0
