Bandit's engine is an AH-style Tecumseh...if it's 98cc, it's an AH600...there's a smaller displacement AH that looks the same externally, but the bore and stroke are less.
There should be a tag on yours with a model number and serial number.
I'm not sure exactly what all is the difference for the model numbers to = an AH engine.. But I know for the (minibike correct) (old school) AH Tecumsehs.. The motor Bandit has is just nothing alike.. I'm not sure about block or anything but that would be like the end of the line.. Those snow blower engines were made in like the 80's... I have used them and they work good and all.. I just posted pics of these two.. First is about exactly like Scooterboys lawn mower engines (vertical shaft bottom reed plate) Then the other is ABOUT LIKE Bandits (IE came in a snowblower) BUT this one is OLD like earlier 70's, but transfering into the (newer Bandit motor style) engines...
The gray one and Bandits motors are pretty well the same thing, only mine is like 15 years older, and is quite a bit different.. Mine has a cast aluminum one piece recoil cover, the air duct around the sides is different, they use a different flywheel than the newer engines.. The plug wire comes out at different places.. The newer engines like Bandits are tipped back and the reed plate is at an angle (and I want to say lower) than the older engine that feeds in at a direct 90...
Not sure where the differences all unfold.. But mine is much closer to (Minibike correct AH engines) But is still a far cry from rite..
I didn't write down the model numbers but I know the white vert motor was Tec T XXX something with Power Products on the ripcord socket And the solid aluminum one is 70's and says Tecumseh model, L XXXX blah blah...
If it will help I'll get the numbers from them both.. :laugh: Not sure how much you can teach me as I am unaware what all is what.. But I do know the 1983 snow blower engines are SOOOoooooo far from being 1971 Bird Engineering motor correct it's not even funny... :lol:
They will work with very little tinkering though.. I am about to build (%100 correct AS POSSIBLE) Rat motor from mine.. :lol: I wouldn't mind learning a little more about them.. I still have the two (AH?? Tecs) in the chainsaws too.. :shrug:
OH and I picked up that West Bend boat engine if anyone wants to compare notes on those too..
