I have a take off carb from a HF 6.5 clone. It is brand new, only gas run through it was from the factory. I installed a .92mm jet and it will also come with a brand new hi flow air filter adapter. The adapter has the nice thick rubber coated gasket to allow proper spacing for the choke lever hold to fit correctly. As pictured, you can see a small nick on the face of the adapter. I'm not sure where along the way it got this, but it obviously in no way affects performance.
note - only one nut is pictured, and the alignment was not perfect when I took the picture. It was just to hold everything in place. I will include two lock nuts to bolt this carb to your engine.
$45 shipped to lower 48.
